Voltage Spike
Old Apr 19, 2010 | 03:30 AM
Rebhays27's Avatar
Rebhays27
Default Voltage Spike
I've had this happen a couple of times, I was driving around 70 - 75 highway. my check gauges light came on with the accompanying chime. My voltage gauge was pegged on the high side. I shifted to neutral switched off the engine then restarted. I know this is not good but the voltage problem went away. About a week ago about 3 months and about 2000 miles later same thing happened. i have the 01 5.2 2wd. Any ideas what's going on? as far as performance I never noticed a single thing Although I do have the infernal surging that there seems to be no fix for. I'd appreciate any help.
Old Apr 19, 2010 | 07:11 AM
95RAM360's Avatar
95RAM360
scan the engine light....let us know what code it brings up.
Old Apr 19, 2010 | 09:59 AM
Sheriff420's Avatar
Sheriff420
When mine did the same thing it was a loose negative battery cable. check both battery cables at both ends to make sure they're clean and tight.
Old Apr 19, 2010 | 12:34 PM
Ugly1's Avatar
Ugly1
Could potentially be a failing voltage regulator, but I'd definitely clean up the wiring first as suggested.
Old Apr 19, 2010 | 08:45 PM
J415's Avatar
J415
The volts in these trucks are regulated by the PCM.
Old Apr 19, 2010 | 10:02 PM
Ugly1's Avatar
Ugly1
Yikes. That's an expensive voltage regulator if it goes.
Old Apr 19, 2010 | 10:10 PM
J415's Avatar
J415
Yup...one more reason why Rams can suck sometimes.
Old May 8, 2010 | 07:02 PM
Rebhays27's Avatar
Rebhays27
Default sorry 4 delay
Sorry guys comp problems
the CEL never came on and no codes are listed on my gauge
The cables didn't appear to be loose What is the "PCM" J415 mentioned?
Old May 8, 2010 | 07:09 PM
dhvaughan's Avatar
dhvaughan
Powertrain Control Module - PCM. the computer. its on firewall passenger side, 3? big wire connectors. it performs the voltage regulation somehow??
