Riding Shroudless
Old Apr 19, 2010 | 02:41 PM
RonRacer's Avatar
RonRacer
Default Riding Shroudless
ok i feel like this it a stupid question, but i'm gonna ask anyway. i was staring at my engine bay plotting out some dress up ideas. so i was wondering how harmful to the engine would it be to take the shroud off for good?? i know its purpose so that why i feel this is kinda a stupid question. but it would drastically clean up the bay and i know older trucks didnt have one.....
Old Apr 19, 2010 | 02:59 PM
pcfixerpro's Avatar
pcfixerpro
Well your gonna obviously reduce the cooling effectiveness by removing it. Just depends on how much of a gamble you want to take. I'd leave it but if you really want to clean it up, do an electrical fan swap.
Old Apr 19, 2010 | 03:34 PM
sungod's Avatar
sungod
I think it is there more for safety than functionality. You may want to watch your fingers.
Old Apr 19, 2010 | 03:45 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Could try it and see how it works out , See how much temp difference change you notice , its easy enough to put it back if it doesnt work out, +1 i'd also look into a electric fans also, but they are kinda spendy...
Old Apr 19, 2010 | 04:16 PM
CPTAFW163's Avatar
CPTAFW163
I would never take it off. Ever. i even went to a junkyard to get another shroud because mine dipped down in the middle and was not on the top of the radiator.
Older trucks do not run as hot as ours since they are mainly carbureated.
take it off at your own risk. Remember that 3 things can kill an engine:
1. Dirt (air and oil)
2. Heat
3. late oil changes
Heat is the biggest killer.
Old Apr 19, 2010 | 04:47 PM
olyelr's Avatar
olyelr
2. Heat
3. late oil changes
Water is pretty harsh on them too.
Old Apr 19, 2010 | 04:52 PM
jps's Avatar
jps
I tried it after dropping an engine in. Temps do go up quite a bit when idling and this was in maybe 20c weather. Without the shroud it just blows air around the engine bay instead of sucking enough through the rad
Old Apr 19, 2010 | 04:55 PM
RamSport97's Avatar
RamSport97
Yeup, its there for a purpose, leave it. If you do not want a shroud, get an e-fan.
Old Apr 19, 2010 | 05:43 PM
Gerehead8's Avatar
Gerehead8
E-fan Spendy? Maybe for one of the dual setups and shrouds but I have a single 16 summit brand fan and an adjustable controller (about $130 total) and I have no overheating problems. The truck stays cooler than stock even in 75 degree heat in traffic. Eventually I will upgrade to dual summit fans and an aluminum shroud off ebay.
Shroud http://cgi.ebay.com/ebaymotors/Dodge...Q5fAccessories
Old Apr 19, 2010 | 07:02 PM
RonRacer's Avatar
RonRacer
yea.... not sue if i want to play with the engine temp in the south(Ga-Al) during the summer time. it gets pretty dam hot around here. just wanted to see if anyones done it. i will look into e-fans though thanks guys
