my ram 1500 making a knocking noise from right wheel when turning
Old Apr 19, 2010 | 10:23 PM
dspitko1's Avatar
dspitko1
Default my ram 1500 making a knocking noise from right wheel when turning
hey guys.....weekend warrior...i have a 98 ram 1500 that makes a hell of a knocking noise from the right wheel when turning the wheels. Would this be the ball joint(s)? only when i turn the wheels to the left. if not the ball joint(s)...any ideas what it could be?
many thanks
Old Apr 20, 2010 | 12:08 AM
yakkier's Avatar
yakkier
It's either going to be the wheelbearing
IF it's a 4x4 then it could possibly be your passengerside axle shaft U joint going bad or gone bad, which is a common issue with us.
Old Apr 20, 2010 | 07:09 AM
95RAM360's Avatar
95RAM360
it has to be either
u-joint
wheel bearing
ball joint
or even possibly the gearbox may be on its way out...check the PS fluid.
Old Apr 20, 2010 | 07:14 AM
dspitko1's Avatar
dspitko1
well since it is a 2wd drive and I replaced the bearings a few months ago I think we nailed it to the ball joints.
how hard are these to replace?
Thanks guys!
Old Apr 20, 2010 | 07:24 AM
95RAM360's Avatar
95RAM360
nailed it to the ball joints?
wheel bearings are easy....get a big breaker bar though...i snapped my 1/2in breaker in half trying to crack the hub nut...then i bought a 3/4in breaker bar, with 2feet of 1in tubing for extra leverage, and both hub nuts popped off with ease...they are torqued to 180 ft/lbs.
