From Stock to Custom Wheel Math Help
Old Apr 20, 2010 | 10:02 PM
gobbell1's Avatar
gobbell1
Default From Stock to Custom Wheel Math Help
I realize the question of backspacing/offset etc.. has been asked many times on this forum. However, I want to ask if my math is correct.
Will you guys with experience in this area chime in?
Current Proposed
Wheel Size 16x7 18x9
Backspacing 5.5" ??
Offset +38mm +20mm
Tire 265/75/16 35/12.5/18
Tire Width 10.5" 12.5"
Relation to Tucked in 1" Sticking out about 3/4"
Fender
I'm thinking that I will gain 18mm (3/4") from the backspacing and another 1" given the wider tire.
1. Does this math sound right to you guys?
2. Will they fit a non-lifted 2WD 1500?
Old Apr 20, 2010 | 11:02 PM
dodgeram07's Avatar
dodgeram07
265/75/16 =31.6
i dont understand this? 35/12.5/18...like a 235/?/18
did you out the 1 1/2" Daystar Leveling Kit
Old Apr 21, 2010 | 09:35 AM
gobbell1's Avatar
gobbell1
Tires are sized in two (2) different ways.
a) 265/75/16 = section width in mm / aspect ratio / rim diameter
Or
b) 35/12.5/16 = outside diameter of tire / section width in inches / rim diameter
The second type of sizing (b) is highly useful for light trucks given that you don't have to do the math to figure out the outside diameter of the tire, it is already spelled out (35")
I still have the daystars in
Old Apr 21, 2010 | 11:41 AM
redheadhunter21's Avatar
redheadhunter21
35's on a leveled 2wd, no offense but keep dreaming
Your looking close to 5 inches to get 35's to fit, 33's with that maybe
Old Apr 21, 2010 | 11:48 AM
gobbell1's Avatar
gobbell1
Redhead,
No offense taken. I asked for honest answers and thats what you gave. Thanks for the feedback. I'll target 33's then.
On the fender/tire spacing issue, does my math jive?
Old Apr 22, 2010 | 05:14 PM
gobbell1's Avatar
gobbell1
bump!!!! Any other opinions?
Old Apr 23, 2010 | 12:51 AM
dodgeram07's Avatar
dodgeram07
3in body lift will clear 35's
Old Apr 23, 2010 | 07:20 AM
olyelr's Avatar
olyelr
No way, not on a 2 wheeler. A 3" body wont clear 35's on a 4 wheel drive without trimming.
To the OP, your math seems quite close, but it is hard for me to add it all up without knowing the new wheel backspacing.
Old Apr 23, 2010 | 06:59 PM
dodgeram07's Avatar
dodgeram07
i had a buddy that had a 2wd reg cab long bed with a 3in body and 35's,,,, tirmed the front bumper and that lower part of the fender
it be a couple of years maybe he had to cut more then
