torque convertor cuts in & out
Old Apr 23, 2010 | 07:36 PM
DukesOfHazzard's Avatar
DukesOfHazzard
I hit 4-5k shifts on a daily basis getting on the freeway with hills and whatnot, yeah i know i will pay for this in the near future,but i cannot drive like a blue hair... and as far as honda's i had a 03 accord with a 2.4 liter and 160 hp , pretty fast for a 4 banger and the 6 cyl has 240 hp i think witch is impressive also, not as much weight obvioulsy, but the 4 banger i had was pretty peppy for 160 hp i sold it and got the NOW dodge, lol. oh yeah no fart can NOT included on mine,lol
Old Apr 23, 2010 | 07:49 PM
95ram5.9's Avatar
95ram5.9
Originally Posted by shadowdiver
When in neutral or park it's fine. As for reving so high, that's when I lay into it when accellerating or passing. I've got 3.55 gears in the rear end usually cruise around 1500 in overdrive and 2k when the OD is off @ 60 mph. The fluid is fine, not burnt or dirty, but sometimes takes time to shift out of 3rd to 4th.
For one, you never wanna "lay into" a Dodge with an automatic.
Old Apr 23, 2010 | 10:27 PM
MonteC's Avatar
MonteC
The truck has 120,000 miles on it with no check engine light. What I'm saying is that when I accellerate and when the engine spins up to 4000-5000 rpm the truck loses all power to the rear wheels. It really feels like a clutch is pushed in and out, alot like a rev limiter in a race car. The rpms start to bounce like the engine is governed. Really hard to explain. Just wondering if anyone else has ever had this issue.
Do a filter and fluid change and adjust the bands. It sounds like the band is letting loose before the shift. If the transmission is working properly it should not hit a rev limiter or governor, unless the band or a clutch pack is letting loose.
Old Apr 29, 2010 | 08:07 AM
shadowdiver's Avatar
shadowdiver
Thanks guys. I was kinda suspecting that there may be a rev limiter but really didn't know if there was or not. I did change all the fluids over the weekend and the shifting has improved, I think the rearend still had the factory dope in it though. I only "lay into it" when I'm running late to work! LOL. Thanks.
shadow
Old Apr 29, 2010 | 08:42 AM
aim4squirrels's Avatar
aim4squirrels
I lay into mine on a weekly basis. I don't care about breaking the tranny, its an excuse to upgrade!
The stock engine can be pushed to the rev limiter with very little fear of something breaking. Upgrade the valve springs and you could raise that to 5500 rpms.
That stock tranny should be able to hold a stock engine's HP output and then a little more.
