torque convertor cuts in & out
Old Apr 22, 2010 | 03:59 PM
shadowdiver's Avatar
shadowdiver
Default torque convertor cuts in & out
I've got a '01 ram 1500 slt with the 5.9, the torque convertor feels like it's locking in and out when rev'ed at high rpm's. Mainly around 4-5 grand it starts cutting and the truck feels like it's about to crap it's guts out on the pavement. Could this be due to the ecm being flashed or am I to maybe suspect the solenoids in the transmission? Or... is this normal because my '93 didn't do this and the ecm was never flashed. It's bugging me.
Old Apr 22, 2010 | 04:09 PM
lastrights's Avatar
lastrights
how many miles on the truck , try running with OD off and see if thats diffrent
Old Apr 22, 2010 | 08:37 PM
MonteC's Avatar
MonteC
What exactly is it doing? Im having a hard time following your description.
Old Apr 23, 2010 | 08:11 AM
shadowdiver
The truck has 120,000 miles on it with no check engine light. What I'm saying is that when I accellerate and when the engine spins up to 4000-5000 rpm the truck loses all power to the rear wheels. It really feels like a clutch is pushed in and out, alot like a rev limiter in a race car. The rpms start to bounce like the engine is governed. Really hard to explain. Just wondering if anyone else has ever had this issue.
Old Apr 23, 2010 | 08:25 AM
95RAM360's Avatar
95RAM360
why are you going up to 4-5 K? have you been beating on it? we have weak trannys, and that milage is around the time for a rebuild....and the TC is usually the culprit....hows the fluid? check while running in neutral...park will not give an accurate reading.
Old Apr 23, 2010 | 01:02 PM
shadowdiver
When in neutral or park it's fine. As for reving so high, that's when I lay into it when accellerating or passing. I've got 3.55 gears in the rear end usually cruise around 1500 in overdrive and 2k when the OD is off @ 60 mph. The fluid is fine, not burnt or dirty, but sometimes takes time to shift out of 3rd to 4th.
Old Apr 23, 2010 | 01:07 PM
95RAM360's Avatar
95RAM360
id change the fluid and filter
Old Apr 23, 2010 | 03:43 PM
EricCartman's Avatar
EricCartman
I wonder if you are hitting the rev limiter...
Cartman
Old Apr 23, 2010 | 04:53 PM
Maxx_Magnum's Avatar
Maxx_Magnum
I would also say you're bouncin it off the chip.... more than likely your 93 didn't have a rev limiter so that would be the difference. these motors don't need to be up in that rev rangefor any amount of time anyways, thats more reserved for 2 liter hondas etc.
Old Apr 23, 2010 | 06:10 PM
95RAM360's Avatar
95RAM360
most hondas around here dont even make it to the 2 liter lol...1.6 and 1.8's HAHA
i live in a city where theres hondas with fart cans around every corner.
