knocking sound on a 1500 97 5.9 magnum
Old Apr 22, 2010 | 11:09 PM
redheadhunter21's Avatar
redheadhunter21
About time and is that when school gets out for you
Old Apr 22, 2010 | 11:20 PM
Maxx_Magnum's Avatar
Maxx_Magnum
If we had a dollar for every time we heard purpl talkin about DIY next week well, we'd all have a few extra dollars at the very least
Old Apr 22, 2010 | 11:27 PM
redheadhunter21
A few I would have enough for a purpl plate aka plenum plate made by purpl
Old Apr 24, 2010 | 11:41 AM
marjess's Avatar
marjess
Thanks guys, that helps...of course it would be good if I could change it myself...If you guys could give me some instructions (with pictures) that would be great ~!!!
Thanks again.
Marcus
Old Apr 24, 2010 | 11:08 PM
marjess's Avatar
marjess
Thanks guys, the DIY manual would be great....
Thanks again for all your help...
Marcus
Old Apr 28, 2010 | 10:08 AM
nicobaires's Avatar
nicobaires
When changing the plenum plate, is it necessary or wise to change the intake manifold gasket as well?
Old Apr 28, 2010 | 01:36 PM
You have to pull the intake, and the gaskets are NOT reusable, so yes, gotta change those too.
Old Apr 28, 2010 | 07:00 PM
Raptor2001's Avatar
Raptor2001
take a look at this and download it.
http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
Open up the pdf and take a look at 9-165
It does not have as many pictures as one of the DIY threads but it should help alot.
Old May 10, 2010 | 03:58 PM
marjess's Avatar
marjess
Hi guys,
So they changed now the intake gaskets and the plenum (huges), but the pinging is still there (acceleration and under load). I put now in total 1500 $ into the truck, that crazy.... I guys I try my luck at the dodge dealer !!! What else could it be ??? We changed already the cat, o2 sensor, clutch van, thermostat, intake gaskets and plenum , computer check and no results, full tune up spark plugs and so on....
Thanks.
Old May 10, 2010 | 04:57 PM
jasonw's Avatar
jasonw
Site Moderator
Were the wires routed correctly per the TSB? Many shops will overlook this.
https://dodgeforum.com/forum/2nd-gen...lug-wires.html
Has the fuel pressure at the rails been checked?
