injectors
Old Apr 23, 2010 | 12:43 PM
ramtruck1500's Avatar
ramtruck1500
Default injectors
will 98-2001 360 injectors work in a 95 318 or is not worth the time
Old Apr 23, 2010 | 01:15 PM
95RAM360's Avatar
95RAM360
im pretty sure they are the same thing.
Old Apr 23, 2010 | 01:54 PM
Gerehead8's Avatar
Gerehead8
They are not the same thing. The later injectors are 23.2 lb/hr and the 95 has 18.2 lb/hr injectors. They will fit as they are externally very similar if not identical (besides top color).
https://dodgeforum.com/forum/2nd-gen...injectors.html
Old Apr 23, 2010 | 02:17 PM
J415's Avatar
J415
Yup, you got that right...
Old Apr 23, 2010 | 04:34 PM
jasonw's Avatar
jasonw
Site Moderator
Not only will they be the wrong rating (lbs/hr) as others have already stated, they also won't necessarily plug into the older harnesses. Can't remember when, but somewhere between 1996-1999, they changed the plugs and the wiring harnesses to a different style. Might have been when they switched to OBD II, but maybe not, I cannot recall exactly.
Old Apr 23, 2010 | 06:04 PM
95RAM360's Avatar
95RAM360
i meant they will hook up
Old Apr 24, 2010 | 01:55 PM
ramtruck1500
would it mess anything up puttin the bigger ones in.
im wondering because im puttin a modded kegger on and while im in there dont know if it worth puttin in the bigger injectors
Old Apr 24, 2010 | 02:34 PM
yakkier's Avatar
yakkier
96.5 is when they switched the connectors for the harness.
Old Apr 24, 2010 | 05:01 PM
jasonw's Avatar
jasonw
Site Moderator
I still am in doubt over the whole "1996 and 1996.5" thing.
But thats beside the point... so they did change the electrical plugs/harnesses when they switched to OBD II. Thanks Yak.
So you'd have to do some custom wiring to get those newer injectors to work.
Old Apr 24, 2010 | 05:30 PM
yakkier's Avatar
yakkier
Not even worth it lol
