Throttle Body boring
Old Apr 25, 2010 | 07:47 PM
1998machz's Avatar
1998machz
Default Throttle Body boring
I have been reading up on the throttle body modifications and was wondering if you bore it to 52mm all the way through. I think what I have read says you just go down to the butterflys. Am I correct? Ihave access to a milling machine and was wondering if I can bore it all the way through or if you just go to the butterflys? Iwill get bigger butterflys made if I have to so that is not a problem. Thanks for any help you can give.
Old Apr 25, 2010 | 07:50 PM
Salex007's Avatar
Salex007
you go all the way through because it starts off from from a 50 i believe down to a 48 so do go all the way through and buy new blades
Old Apr 25, 2010 | 07:55 PM
1998machz's Avatar
1998machz
Okay thanks for the info.
Old Apr 25, 2010 | 08:01 PM
yakkier's Avatar
yakkier
Look up fastman threads there are ton's of them
