Smaller tire size on 16" ram wheels?
I have an 05 dakota and recently put a set of 16" wheels with 265/75/16 tires from an 01 ram on it. The tires are pretty worn out but still rub a little. I did some trimming and most of the rubbing is gone. I need to pick up a new set of tires and I know it will rub more with the new tires. Is there a smaller size tire that will fit on these rims so I won't rub as much? Thanks in advance.
yup. Mine had stock size 245's on em when I got the truck, and I went up to 285's since then.
check this site out, it'll tell you everything about changing tire sizes
http://www.1010tires.com/TireSizeCal...?action=submit
Trending Topics
on
You can put any tire that fits on a 16" rim on there. Since it only rubs a little and it is a street truck then I would go with 255 70 16 or a 255 65 16
Here's a good one http://www.tirerack.com/tires/tires....omCompare1=yes
Where is it rubbing at?
