1994 ram 1500 tranny filter?
Old Apr 28, 2010 | 07:26 PM
konen55's Avatar
konen55
Default 1994 ram 1500 tranny filter?
i have a 94 ram 1500 and somthing happend and now it wont drive in 1,2,3 or D but i got rev. heard tranny filter and bands what would u recommend??? going to try and replace tranny filter first dont wanna out the money for a shop any suggestions???
Old Apr 28, 2010 | 07:34 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
While the pan is off, adjust the bands. If you don't have one, grab a Haynes manual from a parts store. It has all the procedures and the torque settings and everything. Make sure you have a very accurate inch/lb torque wrench.
Old Apr 28, 2010 | 08:13 PM
MonteC's Avatar
MonteC
Definitely not a good sign, drop the pan and check things out. Smell the fluid. Look for debris or sludge.
Old Apr 28, 2010 | 10:42 PM
konen55's Avatar
konen55
the guy i bought it from said the tranny was recently replaced and i talked to a couple of buddies they said tranny filter and bands also it has been leaking quite a bit of ATF but everytime we checked it it has been over full do u think that may have anything to do with it??
Old Apr 28, 2010 | 10:44 PM
konen55's Avatar
konen55
and also does anyone think that the tranny needs replaced?
Old Apr 29, 2010 | 09:55 PM
dhvaughan's Avatar
dhvaughan
i'm no expert (but monte is), but there's little the average shade tree can do with a transmission beyond replacing filter and fluid, maybe adjusting the bands, and looking for shrapnel in the bottom of the pan. you should probably go through with this, although be aware with our expensive transmission fluid, it'll cost about $50 just to change the fluid and filter. but - who knows, you might find a serious overfill, or underfill, or stopped up filter or loose part that can be easily remedied. odds are not good, but you might.
be aware that you should check the fluid with engine running, and truck in neutral, NOT park, and with the silly angle of the dip stick, measure to its lowest solid wet spot.
while checking fluid, look closely at the color and smell. if the transmission was really and truly rebuilt recently, then the fluid will be a nice pink color, and will smell like oil, but not like burnt toast. if your fluid is black, or dark gray and/or smells like burnt toast, then you unlikely have a newly rebuilt trans, and either have an original worn out trans, or a worn out junk yard replacement (which is still technically a replacement).
if your fluid is nasty and shot, your transmission is likely shot too.
since yours is not pulling, you can't even drive it to the shop for a free diagnosis/estimate. that sucks even more.
