yep another tranny prob
Old May 1, 2010 | 01:44 PM
elcheeko's Avatar
elcheeko
Question yep another tranny prob
to start off i have a 01 1500 4x4 5.9l 46re and my problem is that when im drive her down tha road just b4 the trans shifts into o.d. it starts to rattle a bit till i let off the gas and get back on it then it shifts what seems to me is two more gears i dont know if its my tourqconverter or my trannys goin.she has just rolled over 200k the fluid is full and is still red and i have changed the filter about 15k ago.any help would be appreciated thx in advance guys and if theres any gals too
Old May 1, 2010 | 09:05 PM
MonteC's Avatar
MonteC
Sounds like a lock up issue.
Old May 2, 2010 | 08:54 AM
mojo's Avatar
mojo
Default Help For Trany
Sounds like the solenoid between third and over drive. It was a week point in the 46re. You can replace them they are fairly easy for a moderate shadetree mechanic. You need to remove the pan and filter then the valve body. There are two solenoids there is one between 2nd and 3rd as well. I changed both of mine took a morning and about $300 in parts from Autozone.
