Coolant leak- Head gasket??
Old May 1, 2010 | 02:58 PM
95RAM360's Avatar
95RAM360
Default Coolant leak- Head gasket??
ok i was doing the axle seal....again, and when i did it a few days ago, i worked under the truck and there was no leaks.
i moved the truck not 15 feet to work on it again, and now theres coolant splashing down from the back of the motor. i cannot pinpoint the leak. assuming its the head gasket...
what should i look for when coolants leaking out the back? manifold is torqued to spec.
please help...the leak makes about 4 drops to the ground every 10 seconds.
Old May 1, 2010 | 03:06 PM
Sheriff420's Avatar
Sheriff420
freeze plugs or a crap gasket between the intake and the heads.
Old May 1, 2010 | 03:09 PM
DukesOfHazzard's Avatar
DukesOfHazzard
^ thats what first came to mind
Old May 1, 2010 | 03:10 PM
RamSport97's Avatar
RamSport97
plus 1
Old May 1, 2010 | 03:16 PM
95RAM360's Avatar
95RAM360
can i get the freeze plugs in the back of the motor with it in place? or do i need to prop the motor out? and separate tranny?
Old May 1, 2010 | 03:20 PM
Sheriff420's Avatar
Sheriff420
Pull the transmission.
ask lblair about it, he just had to change his.
You need to find out where it's coming from for sure first though. It would suck to pull the transmission and have it turn out the be the intake gaskets.
Old May 1, 2010 | 03:42 PM
95RAM360's Avatar
95RAM360
well i just took a look at it in depth...its not the freeze plugs....i counted 2 on the back side of the motor. and a few on the side...all are new silver looking...thinking PO changed them before.
found that the coolant is leaking from the drivers side, and from what it looks like, it looks like the head gasket....i couldnt really see the back of the manifold...so im going to look there next.
Old May 1, 2010 | 04:02 PM
Sheriff420's Avatar
Sheriff420
Steal a mirror off one of your girlfriends compacts and get a flashlight so you can see the back of the intake manifold.
Old May 1, 2010 | 05:46 PM
yakkier's Avatar
yakkier
That sucks man, but on the driverside it's either going to be freeze plugs or the gasket.
Old May 1, 2010 | 05:54 PM
95RAM360's Avatar
95RAM360
i dont know if its squirting...but the leak does appear to be over the head gasket...I used the hughes intake gaskets and torqued to spec.
