Rear lift blocks for 1500
Old May 2, 2010 | 09:40 PM
GC99RAM's Avatar
GC99RAM
Default Rear lift blocks for 1500
I'm not sure if this would work, but I would like to lift the rear 2" more than stock. I know that the stock 1500 has 3" blocks from the factory and I know that the 3500 has 5" blocks from the factory.
I understand that I can't just jump to Autozone and pick up a 2" block kit because it would be shorter than what is on there and I know better than to stack them.
My question is, could I run to the dealer/Salvage yard and get some 5" blocks from a 3500 along with the U bolts and slap them under the leaf springs to achieve the additional 2" that I am looking for?
Old May 2, 2010 | 10:52 PM
dhvaughan's Avatar
dhvaughan
you'll get several different opinions on this, including using add a leaf springs, using one big block, and stacking blocks.
blocks are low tech and simple. i've seen them stacked with no harm, including reusing u-bolts. nothing wrong with single 5" blocks either.
Old May 2, 2010 | 11:09 PM
Kraiger's Avatar
Kraiger
+ 1. There are alot a opinions out there.. Myself i have a stock 3in block and fabtech 2in block, welded together, under my truck and an add a leaf. So really its up to you. Just getting the 5in block and new u bolts sounds like a good idea to me.
Old May 2, 2010 | 11:20 PM
CPTAFW163's Avatar
CPTAFW163
I had stacked blocks on my 1996, and the u bolts would come loose and my rearend would wobble!!! Needed to get them retorqued every 6 months.
It wobbled so much that my truck was shaking under accelerationa nd my friend following behind me could see it.
But it can be done. Took a year to first notice.
Old May 2, 2010 | 11:36 PM
Kraiger's Avatar
Kraiger
Cant say i have ever heard of that.. I have washers lock washers and nuts on mine and they have been good for over a year now of constant abuse.. That would really stick if you had to keep tightening those.
Old May 2, 2010 | 11:45 PM
sh00tas's Avatar
sh00tas
what about the front end, how would you lift that?
Old May 2, 2010 | 11:50 PM
CPTAFW163's Avatar
CPTAFW163
they were locknuts. WHat happened was the blocks shifted and that messed up how tight the u bolt was. Changed the torque geometry. If you look at the blocks, they are not perfect rectangles.
I wonder if you can weld both the blocks together? I was thinking of getting that done.
Old May 2, 2010 | 11:56 PM
Kraiger's Avatar
Kraiger
Thats what i did, welded my two blocks together.
Old May 3, 2010 | 12:39 AM
GC99RAM's Avatar
GC99RAM
That is a thought about welding them together, but I don't have access to a welder and I am sure they are going to want to charge quite a bit of cash to do that around here.
So would the 3500 blocks and U bolts work?
Old May 3, 2010 | 01:02 AM
Kraiger's Avatar
Kraiger
Yes. If anything the 5in block might be a little bit wider than your 1500 block. but other than that it should work fine.
