What circuit is the cargo light on?
Old May 14, 2010 | 06:49 PM
thegr8schlotzky's Avatar
thegr8schlotzky
I thought it was the third brake light as a week ago or so there was an actual puddle in the driver side footwell..I backed the truck into the incline driveway but usually park front-in with the bed at a lower height. I used a hair dryer to dry up under the carpet of what I saw and replaced the third brake light (figured why not go LED, then had to have the tails match, pic below for kicks) and bought new carpet. I went to install it the other day which is when I noticed it was still wet. It could be that it never really dried up though, as I'm not sure I had the insulation up, and there was a definite gap in the old third tail light.
I'll check the A/C airbox and rear window and such though, thanks.
Old May 14, 2010 | 09:37 PM
thegr8schlotzky
I think the body shop that painted the truck may have screwed up the weatherstripping, and one side is upside down...not sure which. Can someone confirm which way this weather stripping is supposed to be facing? (also where I might be able to find some new stuff as obviously the passenger side is shot)
Driver side:
Passenger side:
Old May 15, 2010 | 07:16 AM
KYHI's Avatar
KYHI
the drivers side is installed correctly
Old May 15, 2010 | 11:57 AM
thegr8schlotzky
Thanks!
Does anyone know where I might be able to find a replacement? All I could find online was full kits for the entire truck for several hundred bucks and door seals, but none of these. Is this a dealer only item?
Old May 15, 2010 | 12:02 PM
thegr8schlotzky
