no power bad gas milage
Old May 5, 2010 | 06:08 PM
JackJ's Avatar
JackJ
O'rielys and auto zone both carry them, my set cost me $20.
Also I am told the the hughes kit comes with it.
Old May 5, 2010 | 06:36 PM
xtreameracer's Avatar
xtreameracer
i got on fel pros web site and looked up the gasket, call them back with the part # and they carry it, it was the same gasket kit they looked up for me, they just didnt know the plate gasket was in with it. whats bad is i asked the first time i call and he said no. they priced it for $27.09 at advance auto
Old May 5, 2010 | 07:44 PM
BIGRED97's Avatar
BIGRED97
do not get just the gasket. it will bow again and you will ahve the same problem
the prblem is the plate is steel, the intake is aluminum, the expand at different rates. also the bolts for the plate cause a problem, not sure if its to long or to short. do some searching probably 1000 posts on it. anyway order a new plenum plate, comes with new bolts, gaskets and instructions from hughes.
this is the kit you want http://www.hughesengines.com/Index/p...p?partid=22220
there is another place, but their name is not coming to me right now.
and here is the DIY
https://dodgeforum.com/forum/diy-do-...e00ram360.html
Old May 5, 2010 | 10:44 PM
CPTAFW163's Avatar
CPTAFW163
Originally Posted by xtreameracer
i just called my local parts store they cant get the gasket for the plate on the intake. anybody know where to get them.
THis:
http://www.hughesengines.com/Index/p...z&partid=22220
ANd the necessary hardware kit:
http://www.hughesengines.com/Index/p...5&partid=23039
you need those bolts because the intake bolts are torque to yeild (Means that they can never be used again when taken out or you will strip the intake).
--Dan
Old May 5, 2010 | 10:45 PM
CPTAFW163's Avatar
CPTAFW163
Oh yeah, it is will downshift on every hill on the highway. Actually, the manual states to TAKE THE TRUCK OUT OF OVERDRIVE when going up a hill.
Old May 5, 2010 | 11:37 PM
Raptor2001's Avatar
Raptor2001
If you plan on keeping the Truck for a while go ahead and get a Hughes Plate.
HUG 7714
HUG 3205B
Edit:
Opps too slow
Old May 6, 2010 | 01:32 AM
Sheriff420's Avatar
Sheriff420
13-15 is average for a 4x4 when the truck is in good condition.
What size are your tires?
Old May 6, 2010 | 02:22 AM
ryans95ram's Avatar
ryans95ram
i had the same problem, do cap, rotor, plugs, plug wires and O2 sensor andf you will be golden
