46re average lifespan?
Old May 6, 2010 | 04:00 PM
Hammer Down's Avatar
Hammer Down
I got about 119,000 miles out of mine. It went very shortly after its first fluid change.
Old May 6, 2010 | 04:06 PM
JackJ's Avatar
JackJ
Maybe its me being a mechanic for a living, or just me being a cold hearted ***, but if you went 119k with out changing it, you deserve it.
Old May 6, 2010 | 04:56 PM
notanexit7's Avatar
notanexit7
Originally Posted by bigdip
Where is the check valve and why would I delete it? Sorry I don't know a lot about automatics.
I wanted to get an aftermarket cooler, but the lines have a fitting on them and dont seem like they would extend well beyond the stock location, what do people do to extend them? just cut off the fittings and use rubber clamps to add hose?
Check valve is the tranny hose coming out of the bottom of the radiator. It collects dirt and grit and crap and overtime will restrict the flow of fluid into the cooler and will burn up the transmission.
Old May 6, 2010 | 05:12 PM
notanexit7's Avatar
notanexit7
Here's a link for removing the check valve.
https://dodgeforum.com/forum/2nd-gen...ve-delete.html
Old May 6, 2010 | 05:31 PM
Hammer Down
That may be if I hadn't gotten the truck at 114,000.
Old May 6, 2010 | 07:38 PM
bigdip's Avatar
bigdip
Ill do that check valve delete, and look into those sensors. Thank you for the help, a lot of good tech on this forum.
Old May 6, 2010 | 10:34 PM
bigdip's Avatar
bigdip
Another thing I forgot to mention was when I give it about 1/2 to 3/4 throttle it shifts like new, can't feel it at all. And when it's floored it feels like its got a valve body kit, has that lurching feeling when it shifts.
It has a JET power control module, could it be controlling the shift firmness?
Old Apr 17, 2019 | 07:34 PM
Derek Townsend's Avatar
Derek Townsend
Default Did you ever figure out what was going on here?
I have the 46re in my 2002 Dodge Durango and it's doing exactly the same thing, under light acceleration it's shifting hard but if I put about 1/2 to 3/4 throttle on it it's shifting like it's fresh off the showroom floor but if I really go at it (full throttle) it has that same valve kit feel of a shift.
Mine is going on 180k I've only put about eight thousand miles on it myself when I first got it it was already shifting kind of wonky like this and I've been trying to hunt down the problem ever since.
The only information I have from before I got the car was that it did have a small vacuum leak when I bought it which I fixed after about only 5 miles of driving it home, the vacuum leak was causing a bit of high idle and overheating though and I don't know how long the old owner went with that going on.
Last edited by Derek Townsend; Apr 17, 2019 at 07:46 PM. Reason: Typo and additional information.
Old Apr 17, 2019 | 08:41 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
This thread is 9 years old they aren't around anymore. Please check the dates before you post
Old Feb 18, 2025 | 05:40 AM
Cdm1974's Avatar
Cdm1974
Default 2000 dakota 4.7 lltr v8 with 400,000 miles same tranny and engine
Originally Posted by 95RAM360
average lifespan is 1-150K miles lol.......ive heard of some lasting over 200K...i have a 46RH, and it last to 178K....
and JackJ, i feel the same way about ALL my fluids...i do diff fluid changes every 10K, tranny/filter 10K, oil 3K, coolant 20K, power steering 25K, and brake, well i still need to flush this.
My 2000 dodge dakota with the 4.7 v 8 has original engine and tranny and only at 400,000 miles (I just rolled over on ) the tranny has started acting up .there's a loud whine when accelerating And I'm pretty sure it my Tor converter going out and .it also has allways since buying it in j2008
