Crossmember How the HELL
Old May 7, 2010 | 02:49 PM
Garter's Avatar
Garter
Default Crossmember How the HELL
98 Ram Had to remove the trans cross member....Now how in the hell do ya get it back in.......seems like the truck was built around it...I have tried EVERYTHING almost,,,,, its as if its a pressure fit to put it in line.. =-'"}what a bitch
Old May 7, 2010 | 02:59 PM
Gerehead8's Avatar
Gerehead8
First time I did it I used the bottle jack in the truck with a piece of wood to spread the frame. The second time I just used some big A** hammers.
Old May 7, 2010 | 03:00 PM
lblair04's Avatar
lblair04
Someone will correct me if Im wrong, but I do believe the frame will flex a little bit when you take crossmembers out. Might try to put a jack between the frame rails or use some heavy rachet straps on each side to pull it apart.
Old May 7, 2010 | 03:03 PM
Garter's Avatar
Garter
thanks much ....i tried bottle jack on the cross member itself....never thought about trying it on the frame....dude I bet its a good 1/2 from lining up....Once again THANKS!!!!!!!!!!
Old May 7, 2010 | 03:31 PM
Sheriff420's Avatar
Sheriff420
I had to use a BFH and ear plugs. You could also use two come a longs hooked to the frame and a tree on each side of the truck or a high lift jack to spread the frame.
EricCartman's Avatar
EricCartman
High-Lift FTW!
Old May 7, 2010 | 03:35 PM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by EricCartman
High-Lift FTW!
I second this wholeheartedly. I've done the bottle jack thing and it's not pretty when the miscellaneous pieces of wood slip and come flying out. The High-Lift is the way to go.
Old May 7, 2010 | 04:45 PM
Garter's Avatar
Garter
YEAH bottle jack did not work at all for me.....why in the F$%^ would dodge make it like this ? stupid!!!! welp borrow the neighbors high lift and try that
Old May 7, 2010 | 04:48 PM
Garter's Avatar
Garter
ps ive been a beat'n on it with a 10 lb sledge to no avail........I just can not understand what the hell they was thinking in the design of that!!!!
Old May 7, 2010 | 05:31 PM
95RAM360's Avatar
95RAM360
try lubing up the sides that hit with old oil, soap or something, so its not going in dry..... lol
