leaky plenum... have a look
Old May 9, 2005 | 07:27 PM
steve05ram360's Avatar
steve05ram360
Default leaky plenum... have a look
Here's a pic of the plenum pan from my intake. notice the nice pool of oil on the rear of the plate? (the rear has the 1/3 circle for the distributor so you know what it is your looking at...) I could not see this looking down into the manifold. what I saw was on the side of the intake which made me think it was leaking. to my supprise, it was leaking down by the distributor
[IMG]local://upfiles/1508/4E17884EAD6749BDB28EBD2FDC79275B.jpg[/IMG]
Old May 9, 2005 | 07:59 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: leaky plenum... have a look
Thanks Steve. I know a lot of people, me included, have wanted to know what to look for in regards to leaky plenum, (since it seems to be such a common problem on Rams).
Good post.
Old May 9, 2005 | 08:11 PM
steve05ram360
What I would recommend to whoever wants to check their plenum is to remove the TB and get a good sized mechanics mirror that you can fit down into the manifold and look ALL the way around with a flashlight. a light coating of oil vapor is ok, pooling is not. you should not have oil running down the plenum like I did when we removed it.
Old May 9, 2005 | 09:30 PM
bamory's Avatar
bamory
How much oil were u going through, thats a crap load. I looked in mine and nothing like that just a nice light film.
Old May 9, 2005 | 09:42 PM
steve05ram360
thats not that much actually, but the thing is it was leaking with the metal gasket. Now that I have the aluminum plenum kit, I'm hoping this doesnt happen again.
Old May 11, 2005 | 07:47 PM
Flynbryan19's Avatar
Flynbryan19
Was it showing oil on your spark plugs?
Old May 11, 2005 | 07:48 PM
Flynbryan19
Thanks for the pic by the way. It gives me a better idea of what I'm looking for.
Old May 11, 2005 | 07:49 PM
steve05ram360
no, they were pretty clean but they were also only in there a short time. 2 months max... old ones were clean to so I dont think this leak was a bad one, but it leaked jus the same...
Old May 13, 2005 | 03:38 AM
Blylock's Avatar
Blylock
Read the TSB, it will tell you how to check a leaking plenum. get the info here
Old May 13, 2005 | 01:13 PM
steve05ram360
that test has been proven to not work all the time, if it is a big enough leak it'll show it but smaller leaks it may not work...
