looking for help on motor swap
Old May 10, 2010 | 11:36 AM
curtisskowaisa's Avatar
curtisskowaisa
Default looking for help on motor swap
I am buying a 94 ram short box and it is cheap and body wise is great shape. The motor has 450,000 km on it and is tired. I also have a 80 ram charger that is beat but I rebiult the 318 and it has about 5000 km on it, can any one tell me if the blocks are the same, can I swap into my 94 with the top end of the magnum?THANKS
Old May 10, 2010 | 04:00 PM
BIGRED97's Avatar
BIGRED97
the ram charger has an LA block and the ram has MAGNUM not the same engines. the magnums got different heads and a few subtle changes. so i do not believe it would be an easy swap. this has been covered a few times, search for LA engine and you should pull up something. tyhat gives you more details.
Old May 11, 2010 | 11:19 AM
curtisskowaisa
Default thanks for the help
thanks for the info, I have not done any reaserch other than this post. I thought some one would know if it can be done or not. I guess the best thing to do is look for donor motor and rebiuld.
