Tailgate Cable
Old Oct 8, 2014 | 12:04 PM
  #31
Bamabrat's Avatar
Bamabrat
Originally Posted by harkdodge
Thanks Bamabrat for the torx size info. Now I can go look for a T45 bit for a couple of bucks. Retired and on Soc. Sec. even $14.00 is a lot of money for tool that I might use once in a life time.
Agree. You could go to advance autoparts with your truck and cables and use their socket and ratchet, then you won't spend anything except gas. I dunno...just a suggestion. At least around here they lend tools for free
Old Oct 8, 2014 | 02:07 PM
  #32
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
When I did mine, I got some cables at Autozone from the self help section. Worked just fine.
Old Oct 9, 2014 | 11:56 AM
  #33
harkdodge's Avatar
harkdodge
I found a T-45 bit at Home Depot for $1.97 and had those cables changed in five minutes.
Old Oct 9, 2014 | 11:57 AM
  #34
Gary-L's Avatar
Gary-L
Veteran: Navy
This is my new favorite thread.
Old Oct 9, 2014 | 12:01 PM
  #35
harkdodge's Avatar
harkdodge
Also, to protect the cables from future rust and breaking again I took a blob of bearing grease and packed it into the open ends of the cable where the cable ends clamp to the cable. This should seal the ends of the cable from water that could find its way into the cable ends and wick its way through the cable.
Just a thought.
Old Oct 10, 2014 | 02:00 PM
  #36
harkdodge's Avatar
harkdodge
In my search for new cables I did find there is a difference in quality.
Some have a smaller diameter cable with cheap light weight ends on the cable.
I found a pair of heavy weight cables with beefy heavier conectors on eBay for just $16.00 and free shipping.
