2nd gen door rust
Old May 13, 2010 | 01:04 PM
htrod02's Avatar
htrod02
Default 2nd gen door rust
Im on my second ram.. first was a 97 short box 4x4 and at 40,000 miles the bottom of the doors started rusting. Dodge actually replaced the doors under warranty. Now im on my second ram a 2000 ext cab with the off-road package. And guess what the friggen doors are starting to rust. They are rusting from the inside out. I am way beyond factory warranty , but damn this seems to be a common occurance. Any one else had this issue and what did you do? Replace doors, skins or what?
Old May 13, 2010 | 02:23 PM
Fairly standard... The bottoms of both my doors are toast. I had figgered on picking up a couple used units from the junkyard, reconditioning them, and putting 'em on. I was considering using some spray on bed liner on the INSIDE of the doors, and then clearing the drain holes. Should solve the problem permanently.
Old May 13, 2010 | 03:04 PM
dodgeram07's Avatar
dodgeram07
i drill a new drains hole in my doors
Old May 13, 2010 | 03:18 PM
GC99RAM's Avatar
GC99RAM
common.. My doors are toast too and I am searching for a good set.
Out here, if you see someone with a good set of doors.. they either just moved here from the south or just replaced them. The quad cab passenger always seem to be the worst
