99 1500 slt laramie 360
Old Jun 2, 2010 | 05:26 PM
  #21
JohnnyZJ's Avatar
JohnnyZJ
the plenum fix will wake it up quite a bit. you can tell when its done.
other thing not stated (that i can see) is the tire size you're running. 285s are about 33 inches tall. much bigger than the stock 29/30 inch tires that come from the factory (245x75r16 i believe) this will make your truck feel sluggish as well.
Old Jun 2, 2010 | 07:41 PM
  #22
SnowFox's Avatar
SnowFox
:P i took that into consideration but it came with 265's so its not much of a difference and gear changes are going to happen later on... like after the plenum and new bushings for the front end... they clunk every now and then....
Old Jun 3, 2010 | 11:47 AM
  #23
JohnnyZJ's Avatar
JohnnyZJ
just ask a women how much difference an inch can make
its not a big step i know. but it does add to the sluggish factor a bit!
gears = good!
