where to buy the CAD bushings/bearings ?
Old May 16, 2010 | 10:50 PM
dhvaughan's Avatar
dhvaughan
Default where to buy the CAD bushings/bearings ?
I had to replace a passenger side u-joint with no warning, and didn't have time to get these bushings and bearings. I'm going to buy a set and have them for a rainy day. I found this 99-01 dana 44 diagram and parts list. d44 is page 12
http://www2.dana.com/pdf/X510-5DSD.pdf
btw, i used Precision 377 super strength greasable from napa, $29 each. very nice joint. it had crappy GMB/Japan joints from prev owner. they were completely dry and rusty and the needles were worn out flat. also, i have no slingers on the end of the axle tubes, and they were full of oily, dirty sand from coastal south carolina. my trucks previous life.
Anyone have any links and prices ?
Anyone know dealer pricing ?
according to note (6, which is really (5)),
(5) Bearing Assembly 566008 was used in older models and is still available for service.
#65 small bushing - 43337
#47 large bushing - 50429
#47 large bearing - 566008
#40 slinger - 45942
43337 - alljeep.com $5.00
http://www.alljeep.com/oscommerce/pr...ucts_id=167486
50429 - drivetrainamerica $3.15
http://www.drivetrainamerica.com/p-6...t-bushing.aspx
http://www.northerndrivetrain.com/pr...SPI-50429.html
566008 - alljeep.com $3.05
http://www.alljeep.com/oscommerce/pr...ucts_id=167605
1-5/8 OD
1-3/8 ID
1/2 inch in length.
edit 1/17/12 bearing is a Timken J228
interchange with INA=SCE 228 - Torrington= J-228
http://www.wbds.com/htm/J228-Tim.htm
http://bearingsdirect.com/store/inde..._detail&p=3692
quad4x4... their web site sucks...
QK4537 2nd design Small Axle Shaft Slinger Kit fits most mid 1970's-1993 SUV, 1/2, and standard 3/4 ton Model 30, 44, 44IFS, and GM 10 bolt front axles. $9.98
sm bushing 43337 and large brg 566008 QK4525 Right Axle Bushing and Bearing Set includes the needle bearing that supports the Output Shaft and the plastic bushing pressed in the end of the right axle shaft on 1994-1999 Heavy Duty (8800 lb or higher GVW) Ram 2500 and Ram 3500 trucks with the Vacuum disconnect system. Dimensionally interchangeable with our QK4646 which was found in 1994-2001 light duty Rams. Made in U.S.A. Includes one bushing and one bearing. $17.98
sm bushing 43337 and large bushing 50429 QK4646 Right Axle Shaft Bushing Kit for 1994-2001, 1500 1/2 Ton and 1994-1997 2500 3/4 Ton (gas engine and under 8800# GVW) Dodge 4x4 trucks. Includes 1 of each bushing. $19.98
riversidegear has them for the ridiculous price of $55 for bushing, bearing, and right side seal. they have slingers for $15 each
Old May 17, 2010 | 07:12 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Just call Dan at Quad4x4
Old May 25, 2010 | 10:29 PM
dhvaughan's Avatar
dhvaughan
ok, for future reference, the large inner bushing (50429) and the inner cage bearing (566008) are interchangeable. i removed the worn out stock bushing from my 01, and replaced it with the bearing. i tapped it out from the driver side, using a 6' 2x2. i tapped in the new bearing, from the passenger side, using a 17 or 19 mm socket, and a short pipe. cad was open, so i was holding it there.
the bushings were probably NOT my problem. the real problem was burrs on the inner axle splines. i filed those out smooth with a flat file.
my collar engagement is now much better.
Old Dec 28, 2010 | 09:06 AM
bobracing32's Avatar
bobracing32
Advance auto parts b5020 and 710241 they both say front interm shaft spicer 44 do these look correct?
Old Dec 28, 2010 | 09:59 AM
dhvaughan's Avatar
dhvaughan
710241 sounds correct for the seal. you can't go by the picture, as Advance uses stock pictures rather than actual one's.
needle bearing - probably. it has no dimensions on the chart.
B5020 nor B-5020 show up in the National chart.
http://www.nationalprecision.com/nee...drawn-cup.html
1-5/8 OD
1-3/8 ID
1/2 inch in length.
