Wheels
Old May 17, 2010 | 05:21 PM
gary30mazak's Avatar
gary30mazak
Default Wheels
I have noticed on some rams incluling my own that if you put a bigger tire on them one tire seems to stick out further (out of the fender wall) than the other unless it is with the stock tires? It is always the passenger side that sticks out. Anybody know why? I mounted 35" by 12.5 on mine just to see what it would look like and it was way off and on craigslist a guy had a 14 .5 and his was way off center is this an axle issue? Its only on the front 2 tires though?
Old May 17, 2010 | 05:27 PM
gary30mazak
I forgot to mention the wheels are identical same offset and evrything
Old May 17, 2010 | 06:45 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Maybe a trac bar issue, that's what centers the axle's, i dunno
Old May 18, 2010 | 08:45 AM
bardram's Avatar
bardram
I have the same problem, only mine is front and rear. Passenger side sticks out just a little more than drivers. And I am only running 265/75/16
Old May 18, 2010 | 09:04 AM
charlie1935's Avatar
charlie1935
That means you can go faster on left turns!
Old May 18, 2010 | 09:08 AM
Wheels/tires shouldn't make a difference. If your truck is lifted in some fashion, or, if the track bar is getting sloppy..... I can see how that might do it.
Old May 20, 2010 | 01:44 PM
gary30mazak
Just FYI it is the trackbar. If you look in the DIY under trackbar installation he has a very good writeup about this issue.
