Can't Find Cruise Control Fuse Anywhere
Old May 10, 2005 | 09:13 PM
Cinch's Avatar
Cinch
Default Can't Find Cruise Control Fuse Anywhere
99 Dodge RAM Quad Cab 4X4 5.2L.... Cruise quit working. The light doesn't come on, so I'm assuming electrical at this point. If so, where is the fuse located? I've looked in dash fuse box, and in the engine comp. fuse panel. I don't see anything with "cruise" or "cc" or anything on it that resembles to me what would be cruise control. Are these things fused? Perhaps it's with something else, and not labelled as such??
Thanks much for any info.....
Old May 10, 2005 | 09:39 PM
steve05ram360's Avatar
steve05ram360
Default RE: Can't Find Cruise Control Fuse Anywhere
the dash fuse panel meaning the one that you can access when the drivers door is open?
Old May 11, 2005 | 11:49 AM
Cinch's Avatar
Cinch
Yep.. Is there another?
Old May 12, 2005 | 07:02 PM
Cinch's Avatar
Cinch
Anyone know where this thing is fused?
Old May 16, 2005 | 04:55 PM
Tani1500's Avatar
Tani1500
when i bought my truck. mine had the same problem. i told the guy when i took the test drive and he said he would fix it. i picked my truck up about a week later and it worked. as i was going home i found the old cc control boxs(the black thing with the buttons) under my seat. I guess he had to replace it. i dont know were yours is. mines on the bottom of the steering wheel. i would try pulling it out and seeing if anthings wrong. ill look at mine and see too.
Old May 17, 2005 | 03:11 PM
Cinch's Avatar
Cinch
Thanks.. I'll check into that..
