adding fog lights
Old May 18, 2010 | 07:27 PM
codyselcamino's Avatar
codyselcamino
Default adding fog lights
its been awhile since ive been on here so i searched but couldnt find what im looking for, some of you might know im putting fog lights in my truck, it didnt come factory with them so i got a headlight light switch with fog lights and wired from the factory fuse panel under the hood to the bumper, now for my question, i got a new bumper today and i want to put factory lights in it, the grey inserts, are they fog light specific? because my new and old inserts didnt have any, i hate to do everything like the factory then go get cheap aftermarket lights
Old May 18, 2010 | 07:57 PM
redheadhunter21's Avatar
redheadhunter21
yea there is different inserts for with or without fogs but the foglight mounts to the metal bumper
Old May 19, 2010 | 09:12 PM
codyselcamino
great, well i guess ill wait till i find some cheap inserts with the lights in them then, thanks
Old May 19, 2010 | 10:28 PM
redheadhunter21
Yea good luck on that one been looking for a new insert to replace the one that broke when my truck was hit only place I found them is LMC for $40 or so should be able to modify the other ones to work.
Im not sure if you know how the stock ones mount up but I could take pictures for you.
Old May 20, 2010 | 07:13 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You can use the inserts for a non factory fog light. Just use a dremel or hole saw to make the holes bigger.
BTW,just so you know, the insert has nothing to do with mounting the light. The light bracket mounts to the bumper itself as RH21 stated.
Old May 20, 2010 | 07:24 AM
jose13b's Avatar
jose13b
look on ebay
Old May 20, 2010 | 10:41 AM
redheadhunter21
Here is some pictures of how they mount up for reference,
they mount to 2 holes in the bumper and thats it this is how you adjust the angle they face the bolt is similar to a carriage bolt since it has a square part that keeps it from spinning so you only have to tighten one side, it is normally hidden by the upper cover on the bumper
the insert is never touched when dealing with the fogllight mounting and install not sure what other differences other than hole size between the 2
Old May 20, 2010 | 09:37 PM
codyselcamino
alright thanks, thats what i was looking for, ill just dremel it out then, i dont have the lights just yet but im gonna get some soon and wanted to be ready for them, i would look at some of my friends trucks but they are all mangled and smashed off, haha
Old Jan 15, 2016 | 11:22 AM
dbbd1's Avatar
dbbd1
Yeah, it's an old thread but...
Does anyone know the bolt size for these? I am adding fog lights but my bumper just has the square holes, not the necessary bolts. The square hole looks to be about the size of a 3/8 carriage bolt, which I am sure, would be too big for the light mounts. Prob just best to get the factory bolts from the stealer (dealer)?
Old Jan 15, 2016 | 12:03 PM
Moparite's Avatar
Moparite
It's a flat head carriage bolt, I believe the the thread is 5/16-18 but not sure on the length.
