Vacuum line question w/ pic
while checking the vacuum lines, to figure out my Wild Vents issue, I noticed underneath the battery, there's some gadget, LOL. Well a vacuum line runs to the top of it, and there is about a 6 inch section of the vacuum line missing. I can't even tell what the gadget is, due to corrosion on it, and imagine that's why the vacuum line is broken.
Does anyone recognize the line? or the gadget? And would it cause my wild vents? I followed the line the other way, and it runs to the vacuum junction deal on the left side of the throttle body, that has a couple other vacuum lines running out of it. I'm not very engine savvy, sorry, or I'd have better explanations. Any help is appreciated.
I'm holding the line where it's broken, and I noticed on the top of that corroded deal, there is what looks like a rubber boot the vacuum line goes to. It is directly underneath my battery, which for some reason is really corroded and gross. Probably time for a new one.
that is the cruise control module I believe.... does your cruise work?
and the wild vents can be fixed by replacing the one way check valve on the vacuum lines to the right of the throttle body.... I might have a pic somewhere of it on mine but if you have a look you'll see it...
omg maxx, I may be in love with u. My cruise light comes on, but no matter how many times I hit the button, it wont work. That most likely is why. Hooray, I'm gonna figure out a way to fix that, and see if it works
Thanks bud. Hopefully fixed one problem, while trying to fix another.
