optimal range for oil pressure
Old May 22, 2010 | 02:18 AM
  #21
CPTAFW163's Avatar
CPTAFW163
rule of thumb...take the first two numbers of your RPMs when it gets past 4000.
The gauge is really there to tell you:
1. "HEY NO OIL PRESSURE"
or
2. "HEY THERE IS TOO MUCH PRESSURE"
Old May 22, 2010 | 09:26 AM
  #22
Originally Posted by minitrucker
my oil pressure light comes on while idleing when its hot...but my motor is also old...once i get the rpms up it goes off...... could i have a messed up sending unit ? im gonna try the aftermarker guage aswell
How many miles on the motor? Could be anything from a bad sending unit, to worn bearings... (in which case, you gauge is NOT lying to you....)
Old May 22, 2010 | 09:37 AM
  #23
charlie1935's Avatar
charlie1935
Originally Posted by jamesnb
Sounds more like a worn out oil pump or you're low on oil. I think the sending unit either works or it doesn't (unless somebody put the wrong one in).
They can be inaccurate like anything else made by man or machine.
Old May 22, 2010 | 10:20 AM
  #24
minitrucker's Avatar
minitrucker
my old old chevy blazer would read no oil presure....then when i hit the gas it would go too the moon ! could be worn sending unit but im guessing worn motor !....... its has around 200+ kms...... i check my oil its not low.....and theres no ticking or knocking
Old May 22, 2010 | 11:55 AM
  #25
I am not entirely sure why, but, pre- 70's GM products had oil pressure sensors that would last forever...... Starting in about the 80's, changing your oil was a gamble on whether the crazy thing would work again afterwards.....
Old May 22, 2010 | 05:24 PM
  #26
jamesnb's Avatar
jamesnb
Fords have awefully low oil pressure.
But as far as sending units...
Different sending units have different ohm ranges. If you have the wrong one installed, it can read 0 psi at idle and then be pegged once the pressure comes up a little.
Old May 22, 2010 | 09:11 PM
  #27
pavement_hater's Avatar
pavement_hater
You got that right. I have heard of some of the old FE big block fords oil pressure being so low that the oil light would come on at idle. But that was just their nature. It never hurt them.
Old May 23, 2010 | 10:13 AM
  #28
minitrucker
my rams oil pressure light does come on at idle !!!!!!!!
