ram 1500 headlight module
Old May 25, 2010 | 10:35 PM
JohnnyZJ's Avatar
JohnnyZJ
Default ram 1500 headlight module
ok, so the daytime running light module in my truck is pooched (canadian vehicle)
so, the daytime running lights work, but my headlights don't come on. both my daytime runners and brights work just fine.
two questions: is it possible that the headlights are shot?
second issue; i pulled a module out of a 96 dodge ( I'm told) but A,the connector didn't fit and B, i 'modded' it to fit and it didnt' run at all. it made no difference; lights were still off.
any ideas? i'd like to have my lights back!
Old May 25, 2010 | 10:45 PM
possible the 'multifunction' switch has gone belly up.
Old May 26, 2010 | 12:35 AM
sprntpshr's Avatar
sprntpshr
Dorman products makes a replacement headlight module, until now it was a dealer item if available at all....
sprntpshr
Old May 26, 2010 | 02:06 AM
mrfarrell's Avatar
mrfarrell
just leave it unplugged in my 96 if its unplugged i just dont have daytime running lights and the highbeam indicator doesnt come on..on the cluster..but the low and high beams still work
Old May 26, 2010 | 02:23 PM
JohnnyZJ's Avatar
JohnnyZJ
whats the malfunction switch?
Old May 27, 2010 | 01:26 AM
mrfarrell's Avatar
mrfarrell
the multifunction switch is normally referring to the turn signal switch on the steering column he may be referring to the headlight switch thou which is also considered one..is your truck a sport or not? your best bet is to just replace your module with one from the boneyard just match the part number on your module to the one there dakota's and durango's use the same module so check them too
Old May 27, 2010 | 10:52 AM
JohnnyZJ's Avatar
JohnnyZJ
will check the JY for switches this weekend and another module. no clue if it'll fit though.
oh, trucks not a sport either, at least to my knowledge
forgot to add, about the multifunction switch, when i put the headlights on, the park and driving lights come on; just NOT the headlights.
i really am thinkin its two burnt bulbs.
Old May 27, 2010 | 05:10 PM
dodgeboy1979's Avatar
dodgeboy1979
that happened to me a few weeks back, the daytime light moduale crapped out and my daytime runners wouldn't shut off. I just went to chrysler and got the new modual and plugged it in and it was fine.
Old May 27, 2010 | 06:56 PM
dhvaughan's Avatar
dhvaughan
how much did it cost ?
Old May 28, 2010 | 11:46 AM
JohnnyZJ's Avatar
JohnnyZJ
x2 how much?
