34 in tires
Old May 11, 2005 | 10:55 PM
nemar1234's Avatar
nemar1234
Default 34 in tires
i was wondering if i could fit 34 in by 10.5 tires on my truck without too much rubbing. its a 98 reg cab long bed 1500. Thanks.
Old May 12, 2005 | 02:49 AM
dodg_24's Avatar
dodg_24
Default RE: 34 in tires
I have 33's with a small lift on mine and it rubs pretty bad. I'm having to get spacers in the front and a block lift in the back to stop it from rubbing.
Old May 12, 2005 | 03:39 AM
hometheaterman's Avatar
hometheaterman
What size lift you have? I have 33"s with a 3" lift and it doesn't rub at all. I also have rims that stick out the side a ways and don't help it. They come close to hitting at full turn but probably still have a inch or so.
Old May 12, 2005 | 02:01 PM
steve05ram360's Avatar
steve05ram360
I have 2 1/2" lift in the front with 33"s (295's) and no rubbing.
Old May 12, 2005 | 06:01 PM
nemar1234's Avatar
nemar1234
thanks, do you think it would work if i put two inch spacers in the front to level it off? Because the tire i wanna get comes comes in 33 in by 13.5 for the sixteen in rims. i want 10.5. The 34 in tire is 10.5 in wide.
Old May 12, 2005 | 11:53 PM
RebelRam04's Avatar
RebelRam04
the leveling kit definitely wouldn't hurt to have installed. The front clearance is ofcourse the major issue and since the 2" kit can be purchased on E-bay for around $70(for steel not plastic) it's worth it to go ahead and install.
Old May 13, 2005 | 01:16 PM
steve05ram360
damn, 13.5" wide is pretty wide. If you lift the front, be aware of the tracbar problem... I have no proof but i suspect that the higher you lift your truck, the faster the tracbar will wear out. I put in a stock replacement bar from Moog and it lasted about 20k miles with a 2.5" lift. I just installed a beefier bar and i'm hoping it'll last longer than the stocker...
[IMG]local://upfiles/1508/CB507F35108A49D58CAFE07F1B712259.jpg[/IMG]
