360 vs 318???
Old May 30, 2010 | 12:07 AM
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by dawsonhunter
When i remove the oil fill cap i can feel a rush of air like a piston pump... could a valve do this?
Abso-freaking-lutely. Time to pull that head. If it's cracked you might want to refurb another to replace it, otherwise just fix that one up and put it back into service.
Edited to add: While it's off, you might as well check spring pressures, lap the valves, that kind of thing that should always be done when a head comes off.
Old May 30, 2010 | 12:13 AM
GeorgiaDodge's Avatar
GeorgiaDodge
318 vs 360 vs 408........hmmmmmmm
Old May 30, 2010 | 12:51 AM
dawsonhunter's Avatar
dawsonhunter
alright.. i have nothing to loose.. i wont have time to do anything till next weekend... a head is much better than tearing the motor out or replacing it.. there is a place here that rebuilds heads...anything i can do to help on fuel mileage???
Old May 30, 2010 | 01:33 AM
95RAM360's Avatar
95RAM360
IMHO, i wouldnt put a 318 in a 2500....and it would be SOOOO much easier to just repair the head...you could do it yourself.....
and yes torque convertors would have to be changed...they are different between the two
since you just did the plenum, that will help with MPGs
Old May 30, 2010 | 02:56 AM
Ugly1's Avatar
Ugly1
All the normal stuff to increase efficiency. Electric fan, ceramic coated tube headers, high flow cat etc. for the lower cost mild enhancements. Turbos are nice. I think twin turbos would be cool but I bet it gets expensive.
