EQ heads and 1.7's
i think they are talking about piston to valve clearence. not valve cover clearence.
Yes I got 1.72's if you want to be exact. The deck was not touched and I am running the stock cam. I cant remember what the head gasket is will have to look. Had the heads checked out and everything is according to the build. Tall valve covers are a must no clearance at the baffles on the stockers.
Hey hey, no no no.. im smart.
yeah i thought you were talkin cover clearance, so sue me. Brain farts happen.
How much lift is that cam again?
Too short a pushrod definitely would not cause that, but too long possibly could assuming you didn't have a piston to valve hit by the valve being held just slightly open.
Any reason to suspect a broken spring? Intake leak down is most likely am intake valve, is it all valves, or just one or two?
