EQ heads and 1.7's
Old May 31, 2010 | 07:08 PM
  #21
aim4squirrels's Avatar
aim4squirrels
Amy chance the valve guides had too much play with the valves? An out of round guide or uneven wear on the guide is a tell tale sign.
You could also lap the valves with compound and check to see if there is a uniform seal with the heads.
Perhaps that particular brand of rockers has an issue. If you still have the stamped steel stockers you could see if that alleviates the problem.
