Right front axle seal leaking
Check the faqs/diy...i did a write up with pics on how to do it its called, front end diy...any questions ask...ive ripped apart my front end a.few timrs
A couple of things that can cause oil to leak past the seals are.
1 Plugged axle vent tube
2 Bad ball-joints
3 Over full diff
If you have had a oil leak in the front diff it takes some time for the left over oil in the axle tubes to drain out.
The factory service manual can be found here lots of great info in it.
https://dodgeforum.com/forum/2nd-gen...e-manuals.html
2 Bad ball-joints
3 Over full diff
Have already purchased seals, gaskets, Hardware yo do the job.I have my own garage and work on vehicles all the time but ive seen where i need the special installer tool. Do i need this or can i get buy with the rental kits from advance or autozone? How about tool on Amazon that is for dana 44? Any advice would help Thanks.
The actual tool makes it easier, but, folks have also used a length of all-thread, some nuts and washers to install it as well. Don't know if the parts stores would have the tool available, its pretty esoteric.
https://dodgeforum.com/forum/2nd-gen...r-bushing.html
I tried the Yukon tool that's supposed to work in the diff but was underwhelmed by the concept and where it pushes on the seal.
2001 1500 seal started leaking a couple hundred miles ago. Added Blue Devil axle seal conditioner.
Does not leak a drop now.
I am not a big believer in mouse milks. But this one absolutely did the job for me.
