Post-Plenum Issue
Old Jun 6, 2010 | 10:12 AM
SawFan862's Avatar
SawFan862
Did not remove TB, but the gasket was done about two weeks ago. Im not sure how these TBS work, but I dont think so because it will only do it at a dead stop. I tried switching the brake booster to the other vacuum line port. Runs better and think it is right now, but I still have the issue.
Old Jun 6, 2010 | 01:34 PM
CPTAFW163's Avatar
CPTAFW163
Originally Posted by 95RAM360
no, the drivers valve cover tube goes to air box, the pass side is the PCV valve and that goes to the manifold.
my drivers side has them all plugged except the brake booster line on the manifold/.
That is true for 96 and earlier. He has a 2001. Passenger side is airbox, and drivers side is intake.
I know because i had a 1996 and now I have a 2001.
Old Jun 6, 2010 | 05:58 PM
jasonw's Avatar
jasonw
Site Moderator
+1 for locations on a 2001.
Old Jun 7, 2010 | 02:38 AM
99dodge318's Avatar
99dodge318
i know that there are two different versions of the stock intake.
my 99 5.2 has the breather valve onthe passengers side, while my bros 01 5.2 has it on the driver side
Old Jun 7, 2010 | 10:46 AM
98formulaLS1's Avatar
98formulaLS1
My truck has the same problem. It also developed after the plenum switch. My brake booster goes directly to the manifold. The driver valve cover goes to airbox, and passenger valve cover goes to manifold. I think my problem my lay in the vacuum tubing on has the T on the pass side of engine.
Old Jun 9, 2010 | 11:02 AM
98formulaLS1
here's a thought. What if you/we didn't seal our intake manifolds well enough and there's a small leak into one or more cylinders?
