any ideas how 2 fix this gap
Old Jun 6, 2010 | 06:35 PM
NAILS's Avatar
NAILS
Default any ideas how 2 fix this gap
its the same on both sides, the guy i got the truck from said it happened when he hit the ditch. it drives fine so i dont think the frame is bent, any ideas would be great. its a 1998 4x4 1500
Old Jun 6, 2010 | 06:38 PM
95RAM360's Avatar
95RAM360
can you push in that lower portion of the fender?not towards the door, just straight down.
Old Jun 6, 2010 | 06:43 PM
NAILS's Avatar
NAILS
u mean unbolt it and move it?? im kind of nervous 2 what if the bolt holes wont line back up
NAILS's Avatar
NAILS
i would show another picture but it wont let me
Old Jun 6, 2010 | 06:45 PM
95RAM360's Avatar
95RAM360
it looks like that bottom portion isnt even bolted....if it is id say he bottomed out or something and it spread the fenders a bit.
Old Jun 6, 2010 | 06:49 PM
NAILS's Avatar
NAILS
so if i un bolt them i should be a ble 2 adjust them right??
Old Jun 6, 2010 | 06:51 PM
95RAM360's Avatar
95RAM360
its worth a try...if need be drill new holes and put new bolts in.....
Old Jun 6, 2010 | 06:55 PM
UnregisteredUser's Avatar
UnregisteredUser
Don't take the fasteners out, just loosen them and see if you can move the fender into proper alignment. If nothing is bent it should easily enough move into place.
NAILS's Avatar
NAILS
good idea thanks 4 the help i will let u know how it works out
Old Jun 6, 2010 | 10:33 PM
dakotas ram's Avatar
dakotas ram
NO. do not simply "drill new holes" find out the cause of it, theres no telling what could be drilled into, and he doesnt need any extra unneeded holes
you keep saying youre a mechanic and such, yet i see alot of posts with the similar sense to them
