5.2L to 5.9L Swap w/ 46RE Trans. ?
Old Jun 6, 2010 | 08:15 PM
Nando Vazquez's Avatar
Nando Vazquez
Default 5.2L to 5.9L Swap w/ 46RE Trans. ?
I am about to get a new transmission. I am also thinking about switching my current 5.2L for a 5.9L. Will the 5.9L just bolt on and do they both use the same transmission. What modifications are necessary for the swap procedure.
Old Jun 6, 2010 | 08:28 PM
All the V-8s use the same trans. There MIGHT be a difference in torque converters, but, I do not have solid information on that.
Old Jun 6, 2010 | 09:14 PM
Sniperinhisname's Avatar
Sniperinhisname
the 318 is internally balanced while the 360 is externally balanced so i believe heyyou is right and you need a pcm from the 360 truck or it will run either rich or lean...can't remember which or get hemifever to flash a sct for ya
Old Jun 6, 2010 | 09:50 PM
Nando Vazquez
what is an SCT and how much does he charge/
Old Jun 6, 2010 | 10:00 PM
Its a scan tool that can reflash your PCM to run the new motor. Runs around 275 from HemiFever, which is actually cheaper than most places..... Send him a PM.
Old Jun 6, 2010 | 11:48 PM
Nando Vazquez
Cool, can he do performance enhancement programmings too.
Old Jun 6, 2010 | 11:55 PM
bigslick050's Avatar
bigslick050
Well I hear from others on DF that he does "custom tunes" but the best way to find out is to just PM him.
Old Jun 6, 2010 | 11:57 PM
Nando Vazquez
K ill do that. but what if the engine comes with its own PCM, will that be alright to run?
Old Jun 7, 2010 | 12:08 AM
GeorgiaDodge's Avatar
GeorgiaDodge
no matter what computer you have when you reciev the tune fro hemifever it will overide all the factory tunes on the PCm it will relearn everything includin timing and whatever else he does. im going to purchase his custom tune as soon as i get the cash together
Old Jun 7, 2010 | 12:58 AM
Nando Vazquez
Thats pretty BA. Ill definetly look into this.
