Another tranny thread
Old Jun 10, 2010 | 01:18 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default Another tranny thread
Hows it going I have a 99 1500 with a 318 and started having tranny problems. The past few days it feels like ive lost alot of low end power. Then tonight i was leaving work and it revved to 2000 RPM before it started to go anywhere. Could I luck out and just need a fluid and filter change? Or do you think I need a rebuild. I plan on changing the fluid and just wondering how much ATF4 to use? Also if it needs to be replaced does anybody know a good tranny shop in the SF bay area? thanks for your help.
Edit.. Its a 46RE I belive
Old Jun 10, 2010 | 02:50 AM
J415's Avatar
J415
Rebuilds aren't that hard. I did my own for about $500. Are you low on fluid? What color is it? It should take about 4-5 quarts.
Old Jun 10, 2010 | 12:04 PM
1998ram5.9's Avatar
1998ram5.9
check your fluid first. That will tell you. Start and warm up the truck then put it in neutral while still running and check it. If its burnt then most likly u need a rebuilt. If its low the add some then drive it.
Old Jun 10, 2010 | 01:12 PM
Zeppelinrocks
I checked the fluid last night as soon as i got home, the fluid level was fine but it was black and smelt burnt. I dont have the time to do my own rebuild its my DD.
Old Jun 10, 2010 | 01:18 PM
J415's Avatar
J415
If it smells burnt, then it's shot. I wish I had a tranny shop to recommend to you, but I just haven't found anyone I could trust in the bay. Just out of curiosity, how many miles do you have on it?
