HELP! Spark Plug Wire issue
Old Jun 12, 2010 | 01:26 PM
AdamR88's Avatar
AdamR88
Default HELP! Spark Plug Wire issue
I am not a machanic and made the dumbest mistake possible when replacing my distributor cap and spark plugs...I pulled the plugs completely off first. Anyway, where I am at now is trying to figure out what length is appropriate each cylinder...I have the firing order diagram...can anyone help me with which length goes to what? Fortunately I have them seperated in 2 groups because 4 of the wires were tied together and I was able to measure that.
Old Jun 12, 2010 | 01:31 PM
truegent81's Avatar
truegent81
so the issue is that you cant figure out what length wire goes to what plug?
Old Jun 12, 2010 | 01:32 PM
AdamR88's Avatar
AdamR88
Exactly...yes a very dumb delimna that should have been avoided
Old Jun 12, 2010 | 01:41 PM
Longest goes to one and two.
Next length goes to 3 and 4.
Etc.
Firing order is stamped on the top of the intake manifold. Just make sure the firing order on the cap is correct, for which wires you put where. Also, have a gander at the TSB on spark plug wire routing in the DIY section.
Old Jun 12, 2010 | 01:45 PM
AdamR88's Avatar
AdamR88
thanks man...that makes my job ALOT easier
Old Jun 12, 2010 | 01:53 PM
greenmachine's Avatar
greenmachine
hmmmm
Old Jun 14, 2010 | 05:33 PM
DukeSupes's Avatar
DukeSupes
Firing order goes in a clockwise rotation around the distributor....just in case you still needed that.
