Brakes went out... where to start?
Old Jun 14, 2010 | 02:12 PM
Sport1500's Avatar
Sport1500
Default Brakes went out... where to start?
Hopped in my truck after getting gas. Had my foot on the brake when I started it and as soon as it started brake pedal went to the floor and I have ABS and BRAKE lights on the cluster. Brakes barely work, I have to push the pedal all the way to the floor. I took a quick look under the hood but didn't see any obvious signs of brake fluid leaking. Some of my hard lines are looking pretty rusty. Where should I start looking? Never had this happen on a car before.
The ironic thing is I drove my truck today because I'm putting a new water pump in my daily driver tonight. The joy of owning cars with high miles.
Rob
Old Jun 14, 2010 | 03:12 PM
beamwalker's Avatar
beamwalker
any leaking from rear drums? sounds like a wheel cylinder went.
Old Jun 14, 2010 | 03:13 PM
edlucky1's Avatar
edlucky1
Rob
Welcome to the Club!
I would first check your brake fluid level. This will tell you whether you are losing brake fluid or if its another issue. I had this issue when the mechanic of the previous owner messed up his brake job and I was loosing fluid everywhere. If your not loosing fluid then I would check your brakes. I found my rear drum brakes to be absolutely horrible, so I would definantly check there next.
Old Jun 14, 2010 | 03:27 PM
Sport1500's Avatar
Sport1500
The fluid level didn't look like it had dropped but I didn't drive that far after this happened so it may not have had a chance. I will have to check out the wheel cylinders. I hate drum brakes! I had problems with them on my old Toyota truck
Rob
Old Jun 14, 2010 | 03:39 PM
Salex007's Avatar
Salex007
my guess is brake line?
Old Jun 14, 2010 | 03:47 PM
Sport1500's Avatar
Sport1500
Definately a possibility. The hard lines look sketchy. This truck has spent its life in Wisconsin and Illinois so it's seen its share of salt
Rob
Old Jun 14, 2010 | 03:59 PM
bigtman07's Avatar
bigtman07
Probably the line above the gas tank. It's notorious for rupturing.
Old Jun 14, 2010 | 04:20 PM
Sport1500's Avatar
Sport1500
Looks like this may be it. I just went out to the parking lot here at work and there is brake fluid running down the side of my gas tank. This is a hard line correct?
Rob
Old Jun 14, 2010 | 04:56 PM
charlie1935's Avatar
charlie1935
Yep. Mine and many others did the same thing. Been a couple of pretty lengthy discussions on this. Try the search feature.
Old Jun 14, 2010 | 05:20 PM
Sport1500's Avatar
Sport1500
Ok thanks alot fellas. I had searched around before posting but I may have not been using the correct words. I found some older threads now.
Rob
