SCT tuner
Make sure everything is tip top shape as far as you can tell. I see in your sig you already have the Hughes plenum kit, and a high flow cat, so you're good there.
You may want to consider a 180 degree thermostat, but the SCT doesn't require that.
EDIT: saw you already have the plenum fix
New list: From www.Rockauto.com
1. Stant 180* thremostat (the 4-5 dollar premium one)
2. Water housing gasket
3. New belt
4. New Idler pulley
5. New tensioner pulley
6. NAPA radiator flush and descaler
--Dan
3. New belt
4. New Idler pulley
--Dan
