Had to get a replacement stub shaft from junkyard
Old Jun 20, 2010 | 02:04 PM
omanalansan's Avatar
omanalansan
Default Had to get a replacement stub shaft from junkyard
I have a 1998 1500 dodge ram 4x4. I replaced my driverside axle ujoint about 2 months ago. I let my brother-n-law borrow the truck. Calls me and says i heard sometthing break lose and now i hear clicking..argh..
Pulled axle out and noticed my stubshaft ear is not a perfect circle anymore. arg again
I finally had time to go to a pick-n-pull yesterday. the only truck i found was a ram 1995 2500. I've read the stub shafts are the same so i decided to pull it. $30 bucks Yippee!!took the whole axle shaft (stub plus ujoints and long shaft).
After looking at my original axle shaft it looks exactly like the same one i pulled from the junkyard.
My gears in my 98 ram is 3.9 and the truck i pulled it off was a 3.5. anything wrong with just bolting up the new shaft in my axle? i'm looking at the spline and they both have 31 spline count.
Old Jun 20, 2010 | 03:56 PM
If the axles are exactly the same, they don't care what gear diff they get plugged into.
Wonder if that was a light duty 2500?? I would like to think the dana 60 uses beefier axles as well than the 44.......
