Improving acceleration?
Old Jun 22, 2010 | 08:57 PM
  #41
CPTAFW163's Avatar
CPTAFW163
On a racetrack, is it legal for someone to sit in the passenger seat working the blower, and someone in the back seat opening up a NO2 tank into said leaf blower?
Old Jun 22, 2010 | 08:58 PM
  #42
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by Augiedoggy
lets help him find whats actually causing his issues with symptoms and facts here rather than blind advice on things to spend money on....
I second this motion!
Old Jun 22, 2010 | 09:03 PM
  #43
Augiedoggy's Avatar
Augiedoggy
Originally Posted by UnregisteredUser
And it's the same differences of linear expansion rates that are responsible for our transmission pan gaskets leaking all the damn time, right? And the fact that the bolts fastening the plenum pan to the manifold are too long is irrelevant, too, I suppose?
Aluminum's coefficient of linear expansion is 12.3*10-6 inches per inch per degree Fahrenheit, while steel's is 7.3*10-6 inches per inch per degree Fahrenheit, which yields a difference of five microinches per inch per degree. So for a delta of 200 degrees, that's two-thousandths of an inch per inch. It's, what, four inches between plenum pan bolts, so .008" total relative motion per gasket segment? If that's going to cause gasket failure we're in trouble all over the vehicle and not just in the plenum pan.
I get beaten down every time I mention the bolts being too long being the real cause and those who have gone to the shorter bolts have never posted back with an issue... the fact is if the two materials being different and expansion and contraction were the real cause my air cooled vw with steel piston sleaves against the aluminum head with no head gasket and a magnesium block would never reach full temp without issues plus the steel valves in aluminum heads? and my alumium manifold would push itself up away from the block and heads on my vette as it expanded more the dodge engineers made mistakes but it was the bolt length and maybe a crappy gasket...
Old Jun 22, 2010 | 09:04 PM
  #44
CPTAFW163's Avatar
CPTAFW163
140k on my engine and plugs are clean as new with 5k since I bought the truck....doesnt burn any oil either so..... I'm just saying you shouldnt assume....its an old truck and waiting till you have an issue before spending money on something that isnt broke aint always the best approach... Sometimes you guys post like you get so many cents on the dollar for every hughes aftermarket plenum kit sold.... lets help him find whats actually causing his issues with symptoms and facts here rather than blind advice on things to spend money on.... He has never stated wheather he in fact has largher tires or not....if he has 31" or larger tires chances are the gears are factory and that could be the biggest contributor to his power woes...
He wanted better acceleration, and wanted advice on a tuner. Hemifever sells the tuner for 275 and HE RECOMMENDS doing the plenum fix and getting a 180* Thermostat.
ALso, APS sells the plenum kit too, for those who think I get money from hughes for telling about their products (funny how you do not mention hemifever with hughes).
You chimed in with the tranny, i chimed in with a tuner. Probably the #1 best bang for your buck that increases performance and MPG.
Old Jun 22, 2010 | 09:12 PM
  #45
Need to know if the OP has the death flash as well. (although, I will grant, it is rather likely......)
Other stuff to know:
Tune up parts?
Fuel Pressure?
Various sensors doing their job?
TV cable adjustment? (if it isn't shifting properly.... well, it just doesn't go like it should)
IS the plenum blown??
Possible partially clogged cat?
Restriction elsewhere in the exhaust?
Old Jun 22, 2010 | 10:08 PM
  #46
UnregisteredUser
What does this argument from authority have to do with ignoring science and engineering in order to perpetuate cargo cult mythology in this thread?
If the OP wants to spend $150 to fix a $30 problem that he may not even have, it's his truck, his money, his time, and not my worry. But if he wants to approach his problem more intelligently than that I'd like to help him to do so. Part of that endeavor is to expose the fallacies in the cargo cult mythology so that he might make his own informed decisions, and that's why I'm making noise about it.
Now, if someone comes along who can use science and engineering to convincingly argue that the steel plenum pan is bad engineering, I'll gladly alter my view in accordance with those facts that are new to me. I've been adjusting my views on things throughout my life, and this might just as well be the next thing about which my mind changes.
In the meantime I'd like to participate in getting 0verdrive happy with his truck's performance because that's part of the reason I visit this forum. So far it sounds like he's got the right approach in mind, and the only thing I'd add to his current plan is that if he's going to stick to external bolt-ons for performance he might be better served by the Superchips tuner over the SCT because:
  • It allows tire size adjustment
  • It comes with a canned "tow safe" tune
  • He has no need of custom tunes
I'd also recommend getting the exhaust opened up some, but not to point of losing the low end that he needs for towing.
Old Jun 22, 2010 | 10:42 PM
  #47
CPTAFW163's Avatar
CPTAFW163
Alright, here is science and technology:
Using your expertise:
Alright, that is EVERY TIME the car is brought to operating temperature and then cools back down. It is the REPEATED heating and cooling that causes separation. The more heating (and the higher the temp) the more of a gap will be when it cools back down. SO lets say that there is a permanent motion of .0001 per time the vehicle is operated, and bigger when the temperature is greater than operating temp. Not to mention greater during winter months when the cooling is faster upon shutoff AND the heating is faster upon startup.
1. You run the engine hot (because of failed water pump or radiator or thermostat) then the expansion is greater and the more warping is done.
2. You are towing, which causes higher temperatures...more expansion.
If you live in cold weather areas, the temperature difference is greater, and the metal cools FASTER.
What happens when you cool heated metal quickly? If becomes brittle and warps.
THis is also a reason why head gaskets leak because of overheating. And what are you supposed to do when you overheat and you have aluminum cylinder heads? You get them resurfaced to home them straight.
And you have hardly used science in any of your arguments, you have been using opinion. I don't know what bug crawled up your ***, but you like to be opinionated without any bearing or reason. Then when confronted, you turtle up and dissapear (reference to the thread where you said i was dishonest for offering someone employment advice.)
Old Jun 22, 2010 | 10:50 PM
  #48
Laramie1997's Avatar
Laramie1997
I recommend that BOTH of you chill out, or take it to PMs.
Old Jun 22, 2010 | 11:22 PM
  #49
kj4cwa's Avatar
kj4cwa
College boys and their silly math numbers! j/k Lighten up guys.
Old Jun 23, 2010 | 12:09 AM
  #50
UnregisteredUser
I'm done, Laramie1997.
