98 ram 1500 no start/spark
Old Jun 21, 2010 | 11:38 AM
CaptChood's Avatar
CaptChood
Default 98 ram 1500 no start/spark
truck:
98 raM 1500 5.2 auto
hey all this is my first post, so hello. i started my truck and it started idling and then i pushed on the gas to rev it up and the truck died and will not restart. i know the injectors are firing because the plugs are wet after trying to start it but its not getting any spark. i replaced the coil. still no spark. so i checked to see if the coil was getting voltage and it is. so i started think cam sensor in the dizzy was bad, after checking to see if the cam sensor was getting 5 volts i found it wasn't so i then checked the tps for 5 volts and there wasn't any voltage there with the key on run. so i check the 5v feed wire from the pcm on the firewall and there wasn't any voltage there either.
the question:
were dose the computer/pcu get the 5v volts or is the pcm at fault?
Old Jun 21, 2010 | 11:51 AM
Check fuse number 9 in the block on the side of the dash.
And Welcome to DF!
Old Jun 21, 2010 | 12:55 PM
CaptChood's Avatar
CaptChood
Thanks
I checked fuse #9 and it was good, swapped in a new one just to be sure and still same problems. i know i'm getting the right volts at the pcm pin A17. How many sensors use that wire for power? trying to find a good wiring schematics/diagram so i can trace them all down. i am thinking i may have a bad sensor thats throwing things off but not sure. any help would be appreciated
Old Jun 21, 2010 | 01:17 PM
Download the factory service manual in the DIY section. It has wiring diagrams up the ying yang. Should have everything you need to know in there.
