95 Dodge Ram 5.9L Misfires on Rev. Help!
Old Jun 21, 2010 | 05:30 PM
Ramt0ugh85's Avatar
Ramt0ugh85
Default 95 Dodge Ram 5.9L Misfires on Rev. Help!
I have a 95 Ram with a rebuilt 360 in her. It will start and idle fine. but when revved up to about 1700 RPM it misfires and pops. We have replaced the MAP sensor, Crank and Cam sensor, IAC sensor, and we have run out of ideas. please help! Thanks
Old Jun 21, 2010 | 05:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
coil,,,,, or cat is clogged.
Old Jun 21, 2010 | 05:54 PM
Ramt0ugh85's Avatar
Ramt0ugh85
i already changed the coil a couple times and gutted out the cat
Old Jun 21, 2010 | 06:04 PM
zman17's Avatar
zman17
Check fuel pressure.
Old Jun 21, 2010 | 06:10 PM
aim4squirrels's Avatar
aim4squirrels
Does it do it on a cold or warmed up engine, or both?
Old Jun 21, 2010 | 06:41 PM
Ramt0ugh85's Avatar
Ramt0ugh85
it does it cold and warm. and it has a new fuel pump i juss put in a few months ago.
Old Jun 21, 2010 | 07:23 PM
What was the original motor? Has this one ever ran right, or is this a new development?
Old Jun 21, 2010 | 11:56 PM
Ramt0ugh85's Avatar
Ramt0ugh85
it is the original motor and i had it running fine. i had it out one day and hit a huge bump and the front tires came off the ground and it shut off. i pulled the crank sensor and it was scratched up from hitting the metal plate on the back of the motor(don't know what is called).so i got a new one, put it in and it started right up, and now its having the misfire.i took it out today and went like a quarter mile and then in shut off. It took a little bit to start. i got it home and punched it down my street and it go up to 2500 rpm and didn't misfire. then i stopped and it started going again and it started misfiring again. and this is where im at now.
Old Jun 22, 2010 | 12:05 AM
Where did you buy the sensor from?
Old Jun 22, 2010 | 12:11 AM
UnregisteredUser's Avatar
UnregisteredUser
It takes some serious pounding to get that much flex out of a flex plate (which Chrysler calls a drive plate)!
You might want to inspect the flex plate to see if it's bent or if there's some foreign material lodged in one of the notches that the sensor reads. If the flex plate is bent you'll want to get it swapped out quick, before it costs you a transmission.
