new truck with new problems
Old Jun 26, 2010 | 09:06 PM
pollocksn's Avatar
pollocksn
Default new truck with new problems
Ok I needed a work truck and found a decently priced 99 ram 4x4. So I bought it for $2000. It is a tad beat up and the track bar is thunking around something horrible. Here is where I need some help. It runs good and has about 150,000 miles on it. Now when I bought it the truck didn't seem to smoke but I get it home I noticed there is black soot on the rear by the tailpipe. It doesnt smoke when I idling it seems to be shooting it out more when the trans is shifting. I am planning on doing a good tune up to it but what should I look at for the smoke?
Old Jun 26, 2010 | 09:25 PM
Look down your throttle body. (engine NOT running...) See any oil? Do a search on "Plenum"... You will find a boat load of threads on that one.
Old Jun 26, 2010 | 09:41 PM
pollocksn's Avatar
pollocksn
I shall sir thanks for the tip.
Old Jun 27, 2010 | 12:36 AM
UnregisteredUser's Avatar
UnregisteredUser
Also check the PCV valve. If it's stuck and a vacuum gauge plenum gasket test doesn't indicate a failure, replace the PCV valve and do a Sea Foam treatment.
If it's stuck and the test does indicate a failure, then of course you want to replace the PCV valve, the gasket (and the bolts that hold the pan to the intake manifold because their being too long caused the gasket failure), AND do a Sea Foam treatment.
Good luck with it!
Old Jun 27, 2010 | 01:33 AM
94excoupe's Avatar
94excoupe
doesnt black soot normally mean an excess of fuel? a black film normally means oil. if im wrong please correct me
Old Jun 27, 2010 | 03:45 AM
sprntpshr's Avatar
sprntpshr
Is the air filter clean? Housing or air inlet crushed somewhere? As stated before might be oil suckage from the plenum too. Sounds like the truck may have had a tough life.
sprntpshr
Old Jun 27, 2010 | 04:21 AM
rumble_truck's Avatar
rumble_truck
or maybe the cat was gutted at some point in its life..
Old Jun 27, 2010 | 04:35 PM
pollocksn's Avatar
pollocksn
I haven't had any time to mess with this truck yet. Been busy with work. Yes I am pretty certain this truck had a tough life. It might have been an old farm truck. It had a 5th wheel hitch in it at one point. there is not a single body panel without a dent or ping of some sort. I am going to start with the basics and check the plenum and go from there. Once I do the plenum which I am sure is leaking I plan on seafoaming it. After I get it running halfway decent its new trackbar time.
Old Jun 27, 2010 | 05:44 PM
pollocksn's Avatar
pollocksn
So went out and looked down the throttle body, def needs a plenum fix. I also found out the airbox is cracked basically in two and the super great dealership didn't bother to tell me it didn't have an air filter in it. So I drove it 30 miles home with no filter.
Old Jun 27, 2010 | 09:00 PM
sprntpshr's Avatar
sprntpshr
Hard to say how long its run w/o a filter and the damage done, sounds like you are on the right track.
