nv3500 tranny fluid
Old Jun 28, 2010 | 01:20 AM
Bubba39047's Avatar
Bubba39047
Default nv3500 tranny fluid
i recently got new ujoints. when itook the driveshaft out i lost some tranny fluid. when i went to find the dipstick to check it. i cant find a dipstick. nor a plact to put in tranny fluid. anybody know where i can check my level?
Old Jun 28, 2010 | 07:38 AM
dhvaughan's Avatar
dhvaughan
i don't have a manual trans, but it should have a fill plug on the side - CAUTION, check the service manual for the location - i read somewhere? about a guy that took the wrong bolt/nut off and ending up having to remove the trans to put it back together.
https://dodgeforum.com/forum/2nd-gen...-gen-rams.html
Old Jun 28, 2010 | 07:44 AM
Bubba39047's Avatar
Bubba39047
my truck came with nothing besides a bedliner and 4 tires basically. ill check on the link
Old Jun 28, 2010 | 12:30 PM
Hahns5.2's Avatar
Hahns5.2
Manuals don't have dipsticks. There's a fill plug on the side, 17mm allen. You can find Pennzoil synchromesh at most auto parts stores.
Old Jun 29, 2010 | 12:18 AM
Bubba39047's Avatar
Bubba39047
driver's side?
Old Jun 29, 2010 | 12:25 PM
Hahns5.2's Avatar
Hahns5.2
Yes. TBH, I pull the shifter out to fill mine rather than mess with getting a bottle of oil stuffed up in there to pour it in, also allows me to overfill it a little, IMO 2 quarts isn't much fluid.
Old Jun 29, 2010 | 12:34 PM
DukeSupes's Avatar
DukeSupes
No, the filler plug is on the passenger side. It is very large and yes its 17mm. You can pick up a kit of hex keys for the 3/8 drive including the 17MM at autozone for 9.99. Be extremely careful not to over tighten it when you put it back.
I read a lot of bad things about the aftermarket NV3500 tranny fluid. I know its costly ($20 a quart), but I went to the dealership and bought three quarts. From completely empty it took just under 2 quarts.
I just took a cap/nipple from a bottle of differential oil and put a small length of vacuum hose on the end and filled at the filler plug. If you want to over fill, jack up the passenger side.
Old Jun 29, 2010 | 05:10 PM
Hahns5.2's Avatar
Hahns5.2
My bad, been a while since I've messed with the fill plug, as I said I fill through the shifter now.
The Synchromesh meets all the same specs as the Mopar fluid.. But for the love of god at least don't use gear oil in a NV3500.
Old Jun 29, 2010 | 08:13 PM
dhvaughan's Avatar
dhvaughan
regarding how to fill it. my son-in-law has a jeep with no room at the rear diff fill plug.
we bought a pump/hose at walmart for a couple of dollars that works great. it has a tube that fits in the bottle and will screw on, then a little plunger thing that you pump, and then a limber little hose about 2 or 3 feet long that you can work into any tight spot. best few bucks ever spent.
Old Jun 29, 2010 | 11:36 PM
Bubba39047's Avatar
Bubba39047
i looked at it. ill probably do it when i do my oil change 1000 miles. i may get a sifen (my spelling is horrible) kit from walmart and give that a go.
