are diesel 2500 4x4's taller than gassers
Old Jun 29, 2010 | 10:43 AM
arenjenkins's Avatar
arenjenkins
that was my first thought, ide bet higher spring rate is the difference. it appears that the rear is the same spring, so i cant imagine the fronts are any taller than the gassers.
Old Jun 29, 2010 | 07:27 PM
ghost4321's Avatar
ghost4321
I'm pretty sure that the diesel and gassers sit at the same height. But putting diesel springs in a gasser will make the gasser sit high because the spring rates are different.
Old Jun 29, 2010 | 09:20 PM
arenjenkins
if the rate is what the difference is i doubt it would be all that noticeable at all. it would only be the front, might level out a hair. how compressed are the front springs with just truck weight on them? it isnt very much is it?
Old Jun 29, 2010 | 09:38 PM
ghost4321's Avatar
ghost4321
Several inches actually, if you jack it up by the frame it takes quite a while for the tires to come off the ground. I'd expect an inch or two putting diesel springs in a gasser.
