Greasing Front End
Old Jun 29, 2010 | 10:54 AM
bluefishkiller's Avatar
bluefishkiller
Question Greasing Front End
Good morning all.....I was just wondering how often everyone greases their front suspension. I drive about 300 miles a week and grease it every Sunday evening. Is this overkill? I have done all the ball joints in the past 2 years and just don't want anything getting dried out. I can usually get one or two pumps with the grease gun on each fitting before it starts to pee out.
Also, can I use that grease for the door hinges? WD-40 drips like crazy and I find myself having to do it once a month so the doors don't make noise.
The grease tube says it's for Chrysler suspensions but if anyone has better suggestions I am all ears.
Thank you all for your time
Jeff
Old Jun 29, 2010 | 03:09 PM
charlie1935's Avatar
charlie1935
WD 40 dehydrates and also will dehydrate any previous lube that happens to remain.
I use a spray white grease.
Old Jun 29, 2010 | 07:17 PM
ghost4321's Avatar
ghost4321
Weekly is overkill, just do it with every oil change.
Old Jun 29, 2010 | 08:08 PM
dhvaughan's Avatar
dhvaughan
weekly is way overkill. i grease mine about every 6 months or so, but every oil change would be a good interval.
any grease is good on door hinges, white lithium or green multi-lube or wheel bearing or anything. i just smear on a little bit. wd40 won't stay on.
